LAG entry returned a NULL value. The entry corresponding to the group ID does not exist, hence could not be removed.
Check if the LAG entry exists for the corresponding groupID. Check if the group ID is correct. show lacp show lacp lag <group-id> {detail} jerry lacp disable <group-id>
Warning
Failed to remove LAG entry as it does not exist. GroupID: %grpID%
| Name | Type |
| grpID | String |
